creating PDF Table from imported chemkin files
Old   September 16, 2014, 04:54
Default creating PDF Table from imported chemkin files
Domenico
idomeneo is on a distinguished road
I'm using Non-Premixed model to simulate combustion through unsteady flamelet. I was successfully able to create a PDF table from thermodynamic database imported from chemkin, but after done that the order of the species in the pdf-mixture material are different from those of the chemkin file.
I tried to modify the order of species in the chemkin files but FLUENT seems to have its own order of species in the pdf-mixture.
Is there any way to keep the wanted order of the species in the pdf-mixture?
I attach the screenshot of what Fluent gives in Materials (chemkin-import is correct but pdf-mixture is not); if necessary I can attach also the chemkin files used.
Thanks in advance, I'll really appreciate any kind of suggestion.
idomeneo is offline   Reply With Quote
Old   November 2, 2016, 06:23
Default pdf creating for partially premixed
Engr. Mehboob Alam
Mehboob Alam is on a distinguished road
Send a message via Skype™ to Mehboob Alam
i am using partially premixed model for coal water slurry fuel combustion.
Is there any way to create a pdf mixture file?
kindly send me the procedure on mehboobalam68@gmail.com
Mehboob Alam is offline   Reply With Quote
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 16:33
[Technical] Creating your own mesh files doug OpenFOAM Meshing & Mesh Conversion 28 April 9, 2009 08:36
creating geometry using "Script files" in ICEMCFD jaber Main CFD Forum 1 November 11, 2007 10:28
PDF Creating for NON_premixed MANOJKUMAR FLUENT 0 February 18, 2006 00:49
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 21:51
