2 phase flow in a flexible microchannel
Old   September 3, 2014, 07:19
Default 2 phase flow in a flexible microchannel
Rahul Halder
rahulju is on a distinguished road
I am working in ANSYS 14 , fluid solid interaction for simulating a droplet flowing through a micro channel.A small part of the channel is flexible.Its dimension is varying from 25*25 um2 to 10 *25 um2.
Time step = 2e10(-6).
velocity = 0.01 m/s
phase = water droplet in mineral oil.
under relaxation parameter used in system coupling:0.2 for both data transfer
for meshing I am using automatic meshing option available in work bench,ANSYS.
The problem I am facing :
though my fluid part in fluent and structural part in transient structural is getting converged.But in system coupling it is not reaching the convergence criteria 0.01.It is oscillating around 0.1 as the droplet getting closer to the constriction and sometimes even before that.
rahulju is offline   Reply With Quote
Old   October 7, 2014, 08:41
Midhun
TechAnalyst2012 is on a distinguished road
Send a message via AIM to TechAnalyst2012 Send a message via Skype™ to TechAnalyst2012
increase the number of elements . or there might be problem with solution methods in fluent
TechAnalyst2012 is offline   Reply With Quote
Two phase flow solid-fluid in river beds Samchak Main CFD Forum 0 May 23, 2013 09:44
Divergence after change in mass flow rate in two phase flow meetsunilkale FLUENT 1 March 25, 2013 04:03
two phase flow + ice phase and breaking soeren87 OpenFOAM Running, Solving & CFD 0 September 19, 2010 11:20
Two phase Flow instability shaoping Main CFD Forum 1 September 8, 2003 14:25
Two-phase/ Single phase mix flow Reza Main CFD Forum 1 August 6, 2003 07:36
