mass imbalance problem
Old   September 2, 2014, 04:22
Default mass imbalance problem
SinYoongWook
iknowjesus is on a distinguished road
HI. fellows.
I'm doing a coal gasificaiton simulation, steady-state solver.
After the simulation with 3000 iterations(but still residual graph shows very unstable), i've found something wrong in the result.
so i've checked other things seriously and found there's mass imbalance in this simulation. mass flow in inlet and outlet had quiet different value.
There was the warning of reverse flow in outlet and i think this is the reason.(am I right?)
Other articles what i have read used this procedure.
1. 'only fluid flow' first
2. add coal particle
3. add chemical reaciton
but in my tries there was not divergence error which make the calculation stop, and so I did fully-adapted conditions. may be this is the reason, too..
would you give me some tips please..?
iknowjesus is offline   Reply With Quote
mass imbalance - what is it? Kombinator FLUENT 0 May 10, 2014 06:39
Problem with changing mass flow rate roo FLUENT 3 June 4, 2013 15:53
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
Convergence problem with target mass flow rate ADL FLUENT 2 May 29, 2012 22:11
Total mass flow/flux through a plane problem nwalters FLUENT 1 December 18, 2010 13:23
