Fluent error: Fatal error (Segmentation fault)
Old   August 25, 2014, 21:09
Default Fluent error: Fatal error (Segmentation fault)
shufang is on a distinguished road
Hi Everyone,
I am running a multiphase simulation (i.e oxygen transfer from air to water). My model enables the species transport. I did not include any UDF, but I kept got error message :Fatal error (Segmentation fault).
If I disable the species transport, it will be okay (but it cannot be disabled because I need to specify oxygen as the transport species).
My current ansys version is 15.0.
Anyone has any idea how to solve this problem?
Thanks!!
shufang is offline   Reply With Quote
Old   April 20, 2015, 06:48
starker
starker is on a distinguished road
Originally Posted by shufang View Post
Hi Everyone,
Thanks!!
Have you discover this problem,,,i'm also have this problem??
starker is offline   Reply With Quote
Old   April 20, 2015, 08:06
Cees Haringa
CeesH is on a distinguished road
it means that the solver is looking for something in the memory, but cannot find it. Did you enable species tracking and set all the species correctly? Also initialized them to some value?
CeesH is offline   Reply With Quote
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 04:22
heat transfer with RANS wall function, over a flat plate (validation with fluent) bruce OpenFOAM Running, Solving & CFD 6 January 20, 2017 07:22
Alias problem when starting FLUENT from command line batch_error FLUENT 0 May 24, 2012 09:20
Fluent 12.0 is worst then Fluent 6.2 herntan FLUENT 5 December 14, 2009 03:57
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 17:48
