Time averaged velocity contour plots
Old   August 23, 2014, 09:11
Default Time averaged velocity contour plots
Tarkes Dora
tarkesdora is on a distinguished road
Send a message via Skype™ to tarkesdora
Hey
I am looking for time avearged contour plots of velocity, HTC and temperature plot. Following is the procedure I adopt to look get time based average contour plot of these parameter
1. Tick on Data sampling for time statistics
2.Define->Custom Field Functions->Select the desired paraemters (say HTC)
3. Sampling option- Custom field function select the parameters
4. Sampling interval default is 1.
After running the simulation then in option of unsteady time statistcs is available in contours and then plot for mean velocity magnitude.
1. Is this methodology of obtaining time averaged velocity plots correct?
2. Can anyone please explain about the sampling interval with an example how it gets averaged. Supposing Sampling interval is 1 and other case say its 4. How does averaging calculation is done w.r.t time? I am looking for averaging initial time step and the last time step results. This understanding would help me in how to do this.
I am new user to FLUENT.
tarkesdora is offline   Reply With Quote
fluent, time averaged, transient analysis, transient average results, unsteady flow
Time averaged fields on a defined time range Yann OpenFOAM Post-Processing 8 August 7, 2019 05:46
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 10:08
How to export time series of variables for one point? mary mor OpenFOAM Post-Processing 8 July 19, 2017 11:54
Time averaged velocity PPPO Main CFD Forum 2 May 3, 2014 19:21
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
