Use Input parameter in the monitor window drag and lift calculation |
August 21, 2014, 10:42 |
Use Input parameter in the monitor window for drag and lift calculation
Meimei Wang
Rep Power: 16 |
How to use Input parameter in the monitor window as shown in the picture attached?
Best regards, Meimei Last edited by Anna Tian; August 21, 2014 at 23:25. |
August 23, 2014, 04:15 |
Meimei Wang
Rep Power: 16 |
Could anyone answer me this question?
Best regards, Meimei |
September 1, 2014, 00:24 |
Meimei Wang
Rep Power: 16 |
Could anyone help on this question?
September 1, 2014, 05:41 |
Rep Power: 17 |
As I know, there is no way to use input parameters for force monitoring directly. But if what you want is to change the parameters for force monitoring automatically, you can use journal files and scripts to conduct this.
September 1, 2014, 06:33 |
#5 | |
Meimei Wang
Rep Power: 16 |
I want to use workbench to run Fluent cases and export the monitor results Cd, Cl directly from the workbench table. In this way, I can change the input parameters simply and copy large amount of Fluent simulation results from workbench to excel directly.
September 1, 2014, 21:44 |
Rep Power: 17 |
If you just want the final result of cd, cl and so on, I mean steady simulation, the result component (actually it is cfd-post)of fluid simulation model in workbench can do it.
Lift and drag calculation | Franny | CFX | 16 | November 27, 2019 14:47 |
wrong SU2 calculation for lift and drag coefficient for NAC4421 | mechy | SU2 | 7 | January 9, 2017 06:18 |
drag and lift calculation of a cylinder in wind tunnel | fewgoodmen | Main CFD Forum | 4 | February 24, 2014 16:05 |
Calculation of lift and drag coefficients | Prachi | CFX | 3 | August 14, 2007 15:05 |
lift and drag calculation | actone | CFX | 0 | December 27, 2006 18:11 |
