August 12, 2014, 18:24 |
Coke wet quenching tower
René Berta
Hi, I am working on project Simultion of Wet quenching tower. I would like to know what could be right setting of paramaters. I would like to have 2 inlets of air and 1 inlet of steam and 1 outlet where would be mixture of air exiting stack (chimney). I need to test pressure and velocity in stack, when I put there instalation (wooden blinds), that could help decrease amount of particular matter of coke exiting stack. I have problem with setting boudery condition of different fluids inlets (air, water wapor or saturated steam or wet steam). Could anyone help my? I have prepared 2D model and meshed with triangular mesh. I have problem what kind of solver to use or if i should use pressure based or density based? And if I should turn on multiphase. I have already try to simulare with energy and standard K- omega and I want use species of coke particles. But I do not know hot to set diferent inlets od steam and air. I need to set mass flow inlet of air and steam in kg /s.
Thank you |
Cooling tower numerical simulation and the technology sharing | ldm273507 | FLUENT | 3 | March 16, 2018 17:10 |
DPM Simulation with Wet Steam | AbbasRahimi | Fluent Multiphase | 1 | June 16, 2015 09:19 |
Cooling tower: several aspects | letzel | OpenFOAM Running, Solving & CFD | 6 | March 15, 2014 04:07 |
Modeling equations for a cooling tower | Ritz_physics | Main CFD Forum | 0 | March 14, 2014 02:02 |
error message | cuteapathy | CFX | 14 | March 20, 2012 07:45 |
