Standard State Enthalpy in Condensation
Old   August 12, 2014, 02:03
Post Standard State Enthalpy in Condensation
Sathya Narayanan
satty_00 is on a distinguished road
Greetings all,
I'm Solving a condensation problem in Ansys Fluent. How do I define the Standard State Enthalpy for steam ( Vapour ) and Water for this process ?
I had checked a Boiling tutorial where they get the SSE of water to 0. And there is also a negative sign used, does it denote heat released ?
Can someone explain the theory in brief please.
satty_00 is offline   Reply With Quote
Old   August 2, 2016, 20:16
Nabeel
Nabeel Jaffar is on a distinguished road
Dear can you please share that tutorial in which you studied to take SSE of water to be 0.
Nabeel Jaffar is offline   Reply With Quote
Old   August 3, 2016, 00:29
Sathya Narayanan
Google ansys fluent boiling tutorial and check out the second pdf link by research gate
Old   June 18, 2019, 08:40
Default Standard State Enthalpy for ANSYS Fluent Water Vapor Condensation
Soumitra Vadnerkar
soumitra2102 is on a distinguished road
What should I edit in case of standard state enthalpy and its reference temperature field for Water_Gas and Water_Liquid material properties in case of simulating condensation phenomenon?
The tutorial document mentioned above deals with water Boiling simulation. There, they have used 0 std. state enthalpy for liquid and 2.992325e+07 J/Kmol for gas both at 25 C reference temperature (even though the boiling occurs at higher temperature and pressure conditions).
This is done for mass transfer to occur from liquid to gas.
My question is, for mass to transfer to occur from gas to liquid, should make Water_gas enthalpy to be equal to 0 and use actual-default std. state enthalpy for Water_Liquid?
Also, please comment on the corresponding reference temperatures.
Thank You.
soumitra2102 is offline   Reply With Quote
Old   June 18, 2019, 08:43
Soumitra Vadnerkar
Here is the link: https://www.researchgate.net/profile...g+Tutorial.pdf
ansys, condensation, fluent, standard state enthalpy, steam
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Boiling simulation ( standard state enthalpy) yasir_hayyat Fluent Multiphase 1 October 13, 2014 04:31
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
error message cuteapathy CFX 14 March 20, 2012 07:45
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
