Fluid-Solid-Fluid Zone
Old   August 6, 2014, 11:05
Exclamation Fluid-Solid-Fluid Zone
Luis Delgado
Luis Delgado is on a distinguished road
Hi, I want to simulate a water flow through a pipe of steel, which is inside a tank of water. I think is not necessary to do the geometry of the pipe, so how can I do to represent the interface between the two fluid zones like the solid wall?
I need somebody help me please. Thanks.
Luis Delgado is offline   Reply With Quote
fluid-solid-fluid-solid, interface domains
Heat Transfer from Solid to Adjacent Solid and then to Adjacent Fluid dkx209 FLUENT 1 July 18, 2013 10:50
goddamnit: how to set up heat transfer from fluid to solid macfly FLUENT 7 June 16, 2012 12:50
Segmentation Fault in fluent3DMeshToFoam cwang5 OpenFOAM Bugs 23 April 13, 2011 16:37
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 02:08
Sliding mesh error Karl Kevala FLUENT 4 February 21, 2001 16:52
