how to find distribution field of reaction rates when CHEMKIN is enabled? |
August 5, 2014, 09:08 |
Edgaras
Rep Power: 12 |
I use FLUENT with CHEMKIN to solve a detailed methane combustion problem with over 300 reactions including chemiluminescence reactions: (1) A + B -> C + X* (2) X* -> X + photon The problem is that i need to know photons generation rate. However, CHEMKIN and FLUENT do not consider photon. Therefore I use equation (2) as follows: (3) X* -> X In order to estimate photons generation rate, for me would be enough to know field distribution of reaction rate (kg/(m^3*s)) of equation (3). Fluent shows reactions rates when CHEMKIN Mechanism is disabled, but when CHEMKIN mechanism is enabled, no information about reactions rate fields are available from Fluent. So my question is how to find distribution field of reaction rates when CHEMKIN is enabled? Sincerely Yours, Edgaras Misiulis, edgaras.misiulis@lei.lt |
February 18, 2019, 10:41 |
samm
Rep Power: 7 |
Hello EdgarasM,
Could you please tell me how to add chemiluminescence reaction in reduced kinetic mechanism... I tried to add OH* and CH* but fluent shows that no thermodata available, if that is the case where can if find thermodata for OH* an d CH*..?and also how did you consider photon in your reaction. kindly help me with your ideas . I know this is an old post. But I need ur help Thankyou, Jegan |
chemkin, fluent, generation rate, reaction rate, species |
FFT on flow field to find peaks? | CFDtoy | Main CFD Forum | 17 | June 7, 2011 07:34 |
combustion - reaction rates - urgent help needed | siri | Main CFD Forum | 2 | March 3, 2007 13:25 |
How can I find maximum of a field | Q | FLUENT | 2 | November 9, 2005 05:00 |
where to find velocity field for square pipes??? | enrico | Main CFD Forum | 2 | February 4, 2005 12:32 |
Where can find airfoil data with pressure distribution or aerodynamic data | Ahlo | Main CFD Forum | 5 | January 12, 1999 23:45 |
