Transition SST k-omega and solver choice for incompressible flow over wing
Old   August 4, 2014, 19:33
Default Transition SST k-omega and solver choice for incompressible flow over wing
Lefteris
Aeronautics El. K. is on a distinguished road
Hi all,
I'm trying to simulate the flow over a simple wing and I'm mostly interested in the transition onset. I'm using a structured mesh and the transition SST k-w model in Fluent. The Reynolds number is about 2e6 and I have tried the coupled solver and the SIMPLE (low speed (28m/s) incompressible flow). However, I don't think I'm getting very sensible results. The mesh I've used for this preliminary analysis is about 2 million cells and the y+ value is below 1 (1.10 max).
Also, in the boundary conditions I leave the intermittency to the default value (1) and I use the intensity and length scale as well (where for the lenght scale I use the 0.4 times the boundary layer thickness).
I suspect that the grid is relatively coarse. I do have two finer grids (about 4 and 8 million cells). Apart from this however, is there anything else I should have in mind that escapes my attention? Which solver would you recommend and what boundary conditions for the turbulence model?
Thanks for your help.
Lefteris
Lefteris
Aeronautics El. K. is offline   Reply With Quote
boundary conditions, solvers, sst k-w, transition
Scaling omega in SST turbulence model TedBrogan Main CFD Forum 0 January 23, 2013 01:00
