August 1, 2014, 19:55 |
Sand-Water Multiphase flow
Hello Everyone,
Recently, I have tried to simulate a two phase solid-liquid flow in a horizontal pipe of 10m length. I used the Eulerian Model in conjunction with the standard κ-ε Turbulence model-mixture model. Furthermore, i treat the flow of solids as granular and have used gidaspow model for drag effects. I use a time step of 0.001 and 5000 time steps (total 5sec of flow). The problem is that when the simulation is completed i receive a higher value of sand volume fraction inside the pipe than the initial value i used. For example my initial sand volume fraction is 0.000538 and the values i receive are 2 orders of magnitude higher, e.g. 0.02-0.03. I think that there is a linearisation problem of the granular kinetic theory models used but i dont know exactly why is this happening.. Could you please help me??? Thank you in advance |
July 15, 2020, 23:49 |
#2 | |
Ravi Agrawal
Rep Power: 13 |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 18:02 |
multiphase flow ,mass and volume fraction imbalance | sope111 | CFX | 16 | September 3, 2018 01:10 |
Review: Reversed flow | CRT | FLUENT | 1 | May 7, 2018 06:36 |
Multiphase Flow with NIST Real Gas Model | Annka | FLUENT | 7 | May 23, 2017 08:58 |
Capillary pressure in multiphase flow in porous media | Lalit | FLUENT | 0 | March 21, 2013 02:24 |
