Pressure Coefficient in wind turbine
Old   July 29, 2014, 10:13
Question Pressure Coefficient in wind turbine
Hazem
mezah is on a distinguished road
Send a message via Skype™ to mezah
I am simulating the NREL phase VI experiment and i want to compare the pressure coefficients at specified location along blade span with the experiment result.
I plotted the pressure coefficient at a specified iso-surface but the results are very far from the experiment.
The question is
is it correct to use directly the pressure coefficient in the x-y plot menu or should i use another formula.
Thanks in advance
mezah is offline   Reply With Quote
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 07:08
Contour of Pressure Coefficient and Velocity Vectors Colored by Pressure Coefficient sonam OpenFOAM 0 August 2, 2012 01:16
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 09:43
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
