July 25, 2014, 13:41 |
Sphere at Mach 7.1
I am running a model with air dissocation reactions. I am currently running laminar flow (though at Mach 7.1 it will not be laminar) and am having the issue that when I enable reactions the Courant number drops suddenly. I am able to run the simulations with species transport enabled. My set-up is as follows: Steady Density Based Axisymmetric Inlet Diffusion Laminar-Finite Rate reactions 5 Species gas model Solution steering - hypersonic (no FMG initialization) If more details are needed, I can provide them. I appreciate the help. |
hypersonic flow |
[ICEM] meshing a sphere - large deviation from perfect sphere | murx | ANSYS Meshing & Geometry | 25 | August 15, 2012 13:37 |
How obtain a Mach number value from a case run with Xifoam solver?? | lfgmarc | OpenFOAM Programming & Development | 0 | June 15, 2011 04:00 |
non-dimensional analysis in Fluent | Endee | FLUENT | 8 | September 7, 2005 17:16 |
meshing F1 front wing | Steve | FLUENT | 0 | April 17, 2003 13:37 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 13:19 |
