Convergence issue for high speed combustion with radiation.
Old   July 24, 2014, 07:32
Unhappy Convergence issue for high speed combustion with radiation.
Goutham S
Goutham cet is on a distinguished road
Sir,
I am currently modelling a supersonic (m=3)combustion of hydrogen injected transversely into the flow field.Using a density based solver ,k E turbulence model .p1 and do for radiation .i am using all under relaxation factor 0.1, combustion includes reaction using mechanism.To get good convergence i initiated reaction mechanism after sufficient iteration.
i am getting the value of residual for continuity is of the order of 9.0204 * 10^-3 after 20000 iteration and remains constant .On the other-hand the residual for energy still remains of the order of 1 to 10^-1 .all the values remains same for any number of iteration.
Is this correct ,or what should i do to bring the convergence of both continuity and energy further down.
Note-good grid quality has been chosen.
Thanks in advance for helpers ...please do help...
Goutham cet is offline   Reply With Quote
Old   July 25, 2014, 14:43
sescobar is on a distinguished road
Hello Goutham,
Did you try to take a look at the local residual values for the energy equation?
This may allow you to elucidate if mesh quality needs to be improved locally.
A quick way to check if this is the cause is to refine your mesh in Fluent based on the local value of energy residual. Then solve for a given number of iterations. If the overall residual drops, then you may have found the cause.
sescobar is offline   Reply With Quote
Old   July 30, 2014, 08:22
Goutham S
Thanks a lot....i tried refining my mesh ...and the problem somewhat cleared , now both are in 1 e^-3 range ,while the mass flow rate shunting between 1333.29-1333.28 units.and its not allowing to converge further.. thinking may be there will be instability's associated flow with combustion.
continuity, energy converngence
Convergence issue with continuity equation Jake FLUENT 8 June 6, 2018 04:41
Speed of Convergence faster with smaller time step Torque_Converter CFX 1 May 15, 2012 20:22
Modeling both radiation and convection on surfaces - Ansys Transient Thermal R13 s.mishra ANSYS 0 March 31, 2012 05:12
Convergence issue in SST for Porous model Raj CFX 0 May 2, 2008 03:43
CFX-Solver, issue with convergence behavior Andy CFX 7 September 5, 2006 04:24
