July 15, 2014, 05:34 |
Turbulence model issues
Carlos
Rep Power: 15 |
Hi everybody!
I am trying to model a pressurized gas injection in a chamber at low pressure. This injection constitutes a supersonic flow near the inlet. The boundary condition that I am considering is a pressure-inlet adjusted with a pressure profile defined with a UDF. I have noticed that the convergence with a RANS or DES model does not harness levels low enough (especially, the turbulence parameters). However, the LES turbulence achieves lower levels with the same solver parameters and boundary conditions. I would like to ask you for an insight to analyze this behavior because I am not sure of how the space filetring performed by the LES model affects the convergence levels. Thanks in advance for your help, |
Turbulence Model - Linking Issues? | AA29 | OpenFOAM Programming & Development | 3 | June 20, 2014 16:21 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
turbulence model for Refrigerator | cicatrix | Main CFD Forum | 0 | October 3, 2012 02:47 |
Low Reynolds k-epsilon model | YJZ | ANSYS | 1 | August 20, 2010 14:57 |
2 stage axial turbine model convergence issues | sherifkadry | CFX | 2 | September 7, 2009 21:51 |
