July 15, 2014, 01:36 |
Abnormal exit of fluent
Rep Power: 13 |
I am trying to run Fluent v14.0 on 8 cores and am having a problem. It works as normal then after several minutes Fluent disappears without any warning. When I check the error log file it says: "Error [node 999999]" Abnormal exit How can I fix this problem?. Any help would be appreciated. |
July 15, 2014, 10:54 |
Rick
Rep Power: 27 |
I had also this problem with parallel solver on an 8 cores single workstation (error after 3-4 hours after starting simulation).
I was running fluent with non ecc ram on an asus z9pe-d8 ws motherboard; when i switched to ecc ram the problem was solved (I think issue was in the specific motherboard, not in ecc/non ecc ram). Maybe it's an hardware related problem.. Daniele |
July 18, 2014, 01:51 |
Rep Power: 13 |
The abnormal exit happened again and this time it has created a .lock file instead of errorlog file...
I'm not understanding whats wrong with my Fluent 14.0.. |
May 1, 2015, 13:50 |
Rep Power: 13 |
My fluent 14.0 worked well till yesterday after changing RAM. Today its just crashed cause of the same problem Abnormal Exit. I am struck and not able to do simulation. It runs only for 10 iterations and disappears automatically. Can you help me to resolve this?
Inside the fluent-0-error.log file Error [node 0] [time 5/1/15 22:8:50] Abnormal Exit! shiv |
May 3, 2018, 05:00 |
Rep Power: 18 |
Hi all,
Resolution: Add the REMOTE_FLUENT_SSH=1 variable to the FLUENT R14.0 Launcher Environment tab before loading your case and data file. Hope this help |
August 2, 2019, 17:46 |
Abnormal Exit 😞
Noushin anan
Rep Power: 7 |
Hello
I know this is an old post. But, I am facing the same problem. Where should I write SSH=1? Should I write it in the environment tab box? THANK YOU |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 04:22 |
Abnormal exit of fluent | shivakumar | FLUENT | 0 | July 15, 2014 01:33 |
Different flow patterns in CFX and Fluent | avi@lpsc | FLUENT | 4 | April 8, 2012 07:12 |
Fluent 6.3 32bit vs Fluent 12.0 64bit | ibex7 | FLUENT | 7 | April 18, 2011 03:44 |
Fluent 12.0 is worst then Fluent 6.2 | herntan | FLUENT | 5 | December 14, 2009 03:57 |
