What Surface Monitor to set to find Mass Flow Rate?
Old   July 12, 2014, 05:17
Default What Surface Monitor to set to find Mass Flow Rate?
Michael
mjkey is on a distinguished road
Hey guys,
I'm trying to find the mass flow rate of my flow as it enters into my passenger cabin. However, I'm not too sure what type of surface monitor I should set, and how I should set it. I've tried using a "point" surface monitor in FLUENT, but it always ends up giving a value of "0". Should I use a line? a plane? And if so, how should these be oriented? What type of "report" should I be choosing if I wanted to check for flow velocity convergence? Mass-Weighted Average?
For example, I'm trying to monitor the flow as it just enters into the cabin, and maybe around the driver head area. How should the surface monitors be oriented?
Thanks alot guys!
mjkey is offline   Reply With Quote
Old   July 14, 2014, 10:35
AGP
Anonymous
AGP is on a distinguished road
You can use the 'mass flow rate' report type in surface monitors and you should calculate mass flow rate through a surface.
You can also calculate the mass flow rate in CFD-post by using the function calculator. I find it a little easier to use CFD post to create planes.
AGP is offline   Reply With Quote
Mass flow rate: calculation v/s computation beguxa FLUENT 5 December 2, 2018 22:02
Split Mass Flow Rate in ANSYS CFX ashtonJ CFX 2 July 9, 2014 04:08
Surface inejction- steady state - mass flow rate CFD-student FLUENT 0 January 25, 2012 14:40
Surface Integral - Mass Flow Rate Venkatesh V FLUENT 3 October 10, 2008 17:18
mass flow rate on the Iso-clip surface & interior Sunil Gupta FLUENT 0 April 22, 2008 10:29
