2D Axisymmetric airfoil cannot report lift!!!
Old   July 5, 2014, 10:10
Question 2D Axisymmetric airfoil cannot report lift!!!
Andy
Mechcaptain is on a distinguished road
G'Day
I'm trying to compare the stall behaviours or an aerofoil in standard planar configuration and Axisymmetric configuration to see if the stall point changes significantly. I am trying to design a difuser for a wind turbine for my bachelor thesis.
The probem is, whist I have had no problem reporting the lift force created by an aerofoil in standard 2D configuration, in axisymmetric setup the Y component of force just reports as zero. This is not physical. Unless of course it is reporting the net force for the whole diffuser ring.
Whilst I do understand the conundrem that in axysymetric configuration the 'lift' force is radial and not strictly in the cartesian Y direction, it is in the Y direction according the slither modeled by the mesh so I expect it should be possible to report lift. But I cannot find any other way to report forces from an axysymetric simulation.
Is there any way I can report force in the radial direction? I can understand it may be be in N/rad or somesuch unit
Mechcaptain is offline   Reply With Quote
Old   July 11, 2014, 01:41
Andy
Really? No-one's got anything???
2d fluent help needed
SU2 AOA optimization 454514566@qq.com SU2 9 March 7, 2022 17:17
2D FFD Optimization RLangtry SU2 2 August 5, 2014 10:48
Problem with restart solution in shape_optimization.py robyTKD SU2 Shape Design 21 May 29, 2013 10:26
2D Inviscid Airfoil model zero lift angle HutchMan FLUENT 8 December 9, 2012 16:04
airfoil 2D simulation: position of lift force on the airfoil Koenieboy Main CFD Forum 2 March 13, 2012 07:44
