To change temperature in mass flow inlet boundary condition per iteration
Old   July 4, 2014, 05:05
Default To change temperature in mass flow inlet boundary condition per iteration
Ajinkya Deshmukh
ajinkya201991 is on a distinguished road
I am a student doing masters project. My topic is Room level air flow modelling for thermal management in data center. I am not getting how to change rack outlet temperature with rack inlet temperature per iteration.
Tout= Tin + (temperature difference)
Rack is modeled by black box approach. Model validation is achieved for rack inlet temperatures. For parametric studies with high supply temperatures , higher rack inlet temperatures are predicted. But rack outlet temperature with mass flow inlet boundary condition is fixed for the CFD case. It should change with higher rack inlet temperature for constant temperature difference for a segment between rack inlet and rack outlet.
Can user defined function (udf) would serve my purpose.I am doing steady state analysis. Can transient simulation only could have this provision.
Also cannot understand a statement mentioned in the research paper for the same. A measured temperature rise corresponding to each segment was imposed in the computational model to simulate the heat generated by the racks.
Please Help.
ajinkya201991 is offline   Reply With Quote
Old   July 11, 2014, 12:29
David
GM_XIII is on a distinguished road
Please Help.
I dont fully get what you mean, please give more info about your BC and domain. I feel i can help you but I can not with the current information. What I have understood by now and correct me if I am wrong is you want to iteratively change the inlet temperature to achieve a specified one in the outlet.
GM_XIII is offline   Reply With Quote
mass flow inlet and pressure outlet with target mass flow rate Zigainer FLUENT 13 October 26, 2018 06:58
Radiation interface hinca CFX 15 January 26, 2014 18:11
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Mass flow boundary condition vivian Main CFD Forum 0 April 11, 2006 00:32
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 07:18
