how to plot new function or variable in fluent?
Old   July 10, 2014, 12:35
Jups
Jups is on a distinguished road
Originally Posted by Hershey View Post
Yes. Since your equation for q is the same in each source, it would be better to define it in DEFINE_ADJUST by saving the value as C_UDMI(c,t,0) = q. Then in the DEFINE_SOURCE you should just reference C_UDMI(c,t,0) instead of q.
In the DEFINE_ADJUST, there are a couple things you must do:
1. You must use begin_cell_loop(c,t) to loop through the cells for C_UDMI. Try looking at Google to fine this and an example.
2. Finally, since DEFINE_ADJUST is called at the beginning of every iteration (not time step), you will want to only calculate q for the first iteration. Look at the following link on how to do that:
http://www.cfd-online.com/Forums/flu...luent-5-a.html
thankyou Hersey,, later i will tell u how the progress..
Jups is offline   Reply With Quote
Old   July 11, 2014, 02:51
Jups
SUN, HERSEY..
i have already try it..
i make q in DEFINE_ADJUST and i use time step 0.001..
it's work.. but the result is not what i want
#include "udf.h"
#define P 3000000
#define T 300
#define e 0.65
#define Rc 500
#define k 0.00013996
#define qe 0.0698337
double q, time, turq;
DEFINE_INIT(q_init,d)
cell_t c;
Thread *t;
thread_loop_c(t,d)
    begin_c_loop_all(c,t)
       C_T(c,t)=300;
       C_P(c,t)=100000;
       q = 0;
    end_c_loop_all(c,t)
DEFINE_ADJUST(adsorpsi,d)
cell_t c;
Thread *t;
thread_loop_c(t,d)
       time = CURRENT_TIME;
       turq = k*(qe-q);
       q = q+turq*time;
       C_UDMI(c,t,0) = q;
       C_UDMI(c,t,1) = turq;
    end_c_loop_all(c,t)
DEFINE_SOURCE(mass_source, c, t)
real source;
source = -((1-e)/e)*C_UDMI(c,t,1);
return source;
DEFINE_SOURCE(y_velocity, c, t)
real source;
source = -C_UDMI(c,t,1)*C_V(c,t);
return source;
DEFINE_SOURCE(radial_velocity, c, t)
real source;
source = -C_UDMI(c,t,1)*C_U(c,t);
return source;
DEFINE_SOURCE(energy_source, c, t)
real ha, source;
ha = 720.9272;
source = -C_UDMI(c,t,1)*Rc*H;
return source;
I attach 2 pictures..
my result is "iterasi udm adjust" pic..
and the result i want is "sahoo" pic..
my case use porosity..
i imagine the result should be is like this..
when the methane flow through inlet,, the pressure and temperature at above is more highly than below... like we say, the vessel is 100cm high..
the pressure and temp at 0cm is different than 100cm..
but my result is same..
have any idea?
Old   October 14, 2014, 02:30
Default hi
  #23
Qureshi M Z I
m zahid is on a distinguished road
hi,
i am facing the similar problem. my UDF of source term is showing zero output. here is my Udf , if anybody know the problem please help me .
DEFINE_SOURCE(xmom,c,t,dS,eqn)
real x[ND_ND];
real source,ve;
C_CENTROID(x,c,t);
ve=sqrt((pow(C_U(c,t),2.0)+pow(C_V(c,t),2.0)+pow(C _W(c,t),2.0)));
source =-1.225*0.2*0.55* C_U(c,t)*ve;
C_UDMI(c,t,0)=source;
return source;
thanks
m zahid is offline   Reply With Quote
Old   October 14, 2014, 02:36
Default hi
  #24
Qureshi M Z I
hi
real x[ND_ND];
real source,ve;
C_CENTROID(x,c,t);
return source;
thanks
Old   October 14, 2014, 08:15
Sun
Sun's Avatar
Sun is on a distinguished road
Make sure "ve" and "C_U(c,t)" are non-zero by printing them out. Also, add dS[eqn] (derivative of source term) before returning the source.
Cheers!
Sun is offline   Reply With Quote
Old   October 15, 2014, 00:12
Default hi
  #26
Qureshi M Z I
thanks for hint. SUN ,
now UDF working
new function, plot
heat transfer with RANS wall function, over a flat plate (validation with fluent) bruce OpenFOAM Running, Solving & CFD 6 January 20, 2017 07:22
LiencubiclowRemodel nzy102 OpenFOAM Bugs 14 January 10, 2012 09:53
Variable Density Function ryzd FLUENT 1 August 25, 2011 15:16
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
