Difference between Transient vs Steady in hydrofoil
Old   June 30, 2014, 04:16
Default Difference between Transient vs Steady in hydrofoil
Lee,Dong Beom
ldb83 is on a distinguished road
Hello~ Everybody~
I am comparing the lift force between transient and steady analysis in same condition.
- realizable k-e model
- pressure-velocity coupling: coupled
- Hydrofoil shape: NACA0012
Transient model
- Inlet horizontal velocity:10m/s
- vertical velocity: 5*sin(5*t) m/s
- max vertical velocity: 5m/s
Steady model
- inlet horizontal velocity: 10m/s
- inlet vertical velocity: 5m/s
When I simulate the above two models, I got the below result.
- Transient model: max CL=2.1 Min CL=-2.31
- Steady model: CL=0.93
The above result is different with my original expectation.
Firstly, I expect the CL will be similar between two model.
because it was expected that the flow in way of hydrofoil will be similar at the max vertical velocity in transient model with the steady model.
Somebody could explain the reason? or Could someone give me relevant document?
It will be very helpful for my study~
Have a good day~ Everybody~
ldb83 is offline   Reply With Quote
difference between steady and transient solution? huangxianbei CFX 13 February 27, 2014 04:20
howto -> perl script for switch steady to transient MainzerKaiser ANSYS 2 February 13, 2012 11:49
What's the difference in formulation for steady state and time-dependent modeling? bearcat Main CFD Forum 5 January 25, 2010 20:30
About the difference between steady and unsteady problems Lisa Main CFD Forum 11 July 5, 2000 15:37
difference between false and true transient mahesh prakash Main CFD Forum 1 January 21, 1999 14:45
