NREL Phase VI Wind Turbine
Old   June 28, 2014, 18:31
Default NREL Phase VI Wind Turbine
vatsal
vatsal1610 is on a distinguished road
Hello guys,
I am performing simulations on the NREL wind turbine (radius:5m) in Fluent and I have generated mesh in ICEM with rotating mesh.
The problem is when I run simulation on 72 rpm it gets diverged and with 0.0005s time step. However I have managed to run the simulation with 10 rpm step of 0.005s and then I will gradually increase the rpm, that is the solution way I found out. I am running simulations with boundary layer because this is my first try. The simulation is running on transient SA turbulence model, Coupled Interface for moving mesh, inlet with 5m/s.
But I don't know how to monitor lift and drag coefficient of the turbine, the obtained values of the Lift coefficient is -20 and drag coefficient is 20 for 2.2 seconds.
Rotational axis is Y
Longitudinal axis is Z
Latitudinal axis is X
and I have set the 0 1 0 for drag coefficient and 0 -1 0 for lift coefficient. and I have selected both surface of the blade.
Image of reference value, residuals, lift and drag coefficient are attached.
Do anyone have idea how to monitor lift and drag coefficient. And what is the solution?
Thanks
vatsal1610 is offline   Reply With Quote
fluent, lift coefficient, moving mesh, reference -values, wind blade
Air Flow Analysis around a Wind Turbine NightHawkRaven FLUENT 4 August 12, 2014 18:18
[ICEM] NREL Phase VI Wind Turbine vatsal1610 ANSYS Meshing & Geometry 4 July 19, 2014 14:00
Simulation of NREL UAE Phase VI turbine aqstax FLUENT 63 June 25, 2014 11:28
BEM Analysis of NREL phase VI turbine er_ijaz Main CFD Forum 11 April 17, 2013 09:04
FSI - Wind Turbine AUN CFX 13 August 29, 2012 17:44
