Reynolds number input in fluent
Like Tree1Likes
Old   June 28, 2014, 17:35
Default Reynolds number input in fluent
Kim
Kim yongchul is on a distinguished road
Dear all,
I would like to validate NACA0012 with experimental result which is available in NASA site. The input mentioned in NASA website is M=0.15 and Re=6 million. I can give M=0.15 in terms of velocity at inlet in FLUENT, but my doubt is "HOW CAN I GIVE RE=6 MILLION IN FLUENT". Thanks for understanding my silly question and please give me the solution.
Thank you so much
Kim yongchul is offline   Reply With Quote
Old   June 29, 2014, 07:20
ghost82's Avatar
Rick
ghost82 will become famous soon enough
you cannot input directly the Reynolds number in fluent.
As you know Re number is defined as:
Re=rho*v*d/mu
Re=Reynolds number
rho=fluid density
v=fluid velocity
d=characteristic length
mu=dynamic viscosity
All in SI units
d in your case, since you have external flow, can be the chord length.
So you can calculate the velocity by fixing your Re number and other physical properties of the fluid and set a velocity input boundary condition in fluent.
Daniele
Kim yongchul likes this.
ghost82 is offline   Reply With Quote
Old   June 29, 2014, 10:24
Kim
Hi Daniele,
Thank you so much for your reply!!
But, i have still some doubt..
As you said, i can fix my "Re" and i can calculate "Velocity". But my objective is inlet Mach number should be 0.15, my Re should be 6 million for validation.
When i calculate Velocity based on my required "Re", the velocity may be different from my Velocity calculated from my required Mach number.
So, how can i my purpose will serve?
Mr.Daniele, i am sorry for struggling you with my silly questions!
Thanks
kim.
Originally Posted by ghost82 View Post
Re=rho*v*d/mu
Re=Reynolds number
rho=fluid density
v=fluid velocity
All in SI units
Daniele
Old   June 29, 2014, 11:56
ghost82's Avatar
Rick
you can calculate velocity based on Reynolds number or Mach number.
If you want to fix Mach number simply calculate velocity as v=(Mach number)*(sound velocity).
Daniele
Old   June 30, 2014, 06:51
Kim
Dear Daniele,
Yes you said is right, we can calculate velocity based on Mach number also. Experimental data (for M=0.15 and Re=6 million) for NACA0012 airfoil is available in NASA website. I need to do simulation on naca0012 in FLUENT and validate with the above mentioned experimental data. So, i have to use M=0.15 and Re=6 million to validate my fluent results with experimental data. So, i can calculate velocity using M=0.15 and i give this velocity at inlet in fluent. But if we calculate the "Re" using my velocity (M=0.15), i will get different "Re" other than Re=6million. So, i cannot validate with experimental data. So, how can i validate now? That is why i asked how can i give Re=6million in fluent as input.
Please let me clarify my doubt in this regard.
Thank you Daniele.
Daniele
Old   June 30, 2014, 07:43
Anonymous
LiteCFD is on a distinguished road
Originally Posted by Kim yongchul View Post
Dear Daniele,
You can try to vary other parameters which are included to Re=rho*v*d/mu
Calculate velocity from M and then decrease/increase mu, for example.
Note that other dimensionless parameters from your equations should be changed correspondingly.
LiteCFD is offline   Reply With Quote
Old   June 30, 2014, 11:10
ghost82's Avatar
Rick
LiteCFD is right; make a pseudo fluid with custom density and/or viscosity to have reynolds=6 million.
Can you share the article you are trying to validate?
Old   June 30, 2014, 11:57
Kim
Hi Danieli,
Please look into the link below
http://turbmodels.larc.nasa.gov/naca0012_val.html
I would like to validate in the above link (naca0012 airfoil)
Thank you
Kim
LiteCFD, thank you very much for your clarification!!
Old   July 15, 2016, 02:56
Default Reynold number
Farshid021 is on a distinguished road
hello everyone
I have simple question
how can I change Reynolds number in fluent
Farshid021 is offline   Reply With Quote
Old   July 15, 2016, 04:39
ghost82's Avatar
Rick
There are various definitions of Reynolds number, depending on your application.
For flow in pipe you have the Reynods (Re) definition:
Re=rho*v*d/mu
rho: fluid density
v: fluid velocity
d: pipe diameter
mu: fluid viscosity
So, accordingly, to change Re you need to change one or more of the above parameters.
Google is your friend and the same for the search button!
Old   July 16, 2016, 11:06
  #12
hello all dear
I have a simple question
how can I change rey number in fluent
for example, I want to insert my rey number 33000
Old   July 16, 2016, 13:01
ghost82's Avatar
Rick
Originally Posted by Farshid021 View Post
hello all dear
Message #11
Old   July 18, 2016, 03:15
  #14
my dear friend, I want to simulate passing flow from the plate by fluent but the problem is I don't know which items depends on rey number
Old   August 3, 2016, 16:35
Thusitha
Thusitha is on a distinguished road
I presume when you say "which items depend" means the quantities that describe the Reynolds number. As far as I remember, its the plate length, flow density, flow velocity, and flow viscosity.
Thusitha is offline   Reply With Quote
Old   May 27, 2017, 05:17
Unhappy characteristic length used by fluent
  #16
JOHOR
derdiyzoe94 is on a distinguished road
hey,i have one question. I do project aerodynamic analysis on car, the problem is I couldn't tell, whether fluent use which type of characteristic length(length or width of my car) to calculate Reynolds number to compute the coefficient of drag .Anyone knows?Thanks in advance.
derdiyzoe94 is offline   Reply With Quote
Old   October 14, 2017, 06:03
Jennifer Von
Jennifer Von is on a distinguished road
I think Cd is related to your flow projected area A=width*height. in 2D flow around cylinders , A=width*1=diameter of cylinder *1
Jennifer Von is offline   Reply With Quote
Old   November 11, 2017, 07:03
Omar Faruk
Omar Faruk is on a distinguished road
Can I fixed Re=1*10^6 where velocity is 10m/s and the fluid is air??? if yes then how i can do this?
Omar Faruk is offline   Reply With Quote
Old   April 24, 2018, 13:07
Lightbulb airfoil
  #19
Msvs
Msvsraj is on a distinguished road
how can we give reynolds number for flow over airfoil
Msvsraj is offline   Reply With Quote
Old   May 10, 2019, 11:53
Lightbulb What about complex geometry?
  #20
Hitesh
Hitesh12 is on a distinguished road
Re=rho*v*d/mu
Re=Reynolds number
rho=fluid density
v=fluid velocity
All in SI units
Daniele
Seems easy when the geometry is simple but what happens when it is not? I have a complex geometry with varying diameter and varying cross-sectional area even for the same dia (because of obstruction in the flow).
What can be done in such a case? What I'm thinking is that we'll have to break down the geometry in different parts and have to calculate Reynold's number for each. Is that the right approach?
Hitesh12 is offline   Reply With Quote
fluent, input, reynolds number
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
Setting Reynolds number in Fluent for plunging airfoil quarkz FLUENT 2 November 20, 2019 00:40
Applications of Reynolds Number Nadeem99 Main CFD Forum 0 December 10, 2012 03:10
Reynolds Number in Fluent danwebb FLUENT 3 March 17, 2011 07:16
Reynolds Number and Heat transfer Coefficient panos_metal FLUENT 0 January 7, 2011 07:37
