Help...Is this typical for two-phase flow using sliding mesh |
June 27, 2014, 11:00 |
Rep Power: 13 |
I am trying to simulate a gear churning into oil in a gear box. I set up a simulation using Fluent sliding mesh. So I constructed an interface between the "inner fluid zone" and "outer fluid zone". The initial condition is that the gear is partly immersed in the oil. Then the gear rotates with a speed of 1000 rpm. The pitch circle speed is around 4.7 m/s and the minimum size of the cell is around 0.1 mm. Therefore I set up the time step to be around 1 E-5.
After a few time steps, the 2 phases look like the picture. The oil surface in the "inner fluid zone" seems to rotate with the region. I though while the inner region is rotating, the two-phase surface should be stable, especially for those far from the gear. This results look not physical in my opinion. Capture.JPG So, is this kind of result typical for two-phase sliding mesh simulation? Is it just an unstable transient solution that I should wait till the results stabilized? P.S. this is not similar with what I got from dynamic mesh or Star-CCM+ overset mesh methods (which seems physical to me). Thank you for your help!! |
June 30, 2014, 05:43 |
Karl Kargl
Rep Power: 17 |
For me it seems you have a wrong setup for the rotating gear. Could you post your settings. Normally there is no problem using the Vof-model together with a sliding mesh.
Best Regards Tip: Using the (rpsetvar 'patch/vof? #t) command in the text-console before patching the heavier phase in the gearbox will give you a smoother interface (right side on your picture). |
June 30, 2014, 11:11 |
#3 | |
Rep Power: 13 |
1.png 2.png 3.png 4.jpg 5.png |
June 30, 2014, 11:13 |
#4 | |
Rep Power: 13 |
9.png 10.png 11.jpg 12.png 13.png |
July 1, 2014, 04:30 |
Karl Kargl
Rep Power: 17 |
No, the settings for the gear wall are ok. Do you have a conformal or non-conformal interface zone ? Which solver settings are you using ?
You should include the "Implicit Body Force" option in your VoF-Settings. Best regards, Karl |
July 1, 2014, 11:45 |
#6 | |
Rep Power: 13 |
Solvers I used are: PISO for pressure-velocity coupling Gradient: Least squares cell based Pressure: PRESTO! Momentum: Second order upwind Volume Fraction: Geo-Reconstruct TKE and TDR: Second order upwind Transient: First Order Implicit Is there anything inappropriate? I guess my error may come from the fact that I did not choose "implicit body force" and did not change the VOF solver from default to "Solve vof every iteration". I am trying with these options selected. Thanks for pointing this out! |
July 10, 2014, 11:43 |
Rep Power: 13 |
Can anybody help? The problem still remains...
March 28, 2017, 02:49 |
Rep Power: 12 |
Use VOF and implicit force .
Check "Sharp" in "Interface Modeling Type". I think it will help the sharpness of the interface. |
fluent, sliding mesh, two phase flow |
Sliding mesh and Momentum Theory | Lam | FLUENT | 2 | February 21, 2013 17:08 |
How to calculate phase flow rate? | sangramroy | FLUENT | 0 | January 11, 2012 14:02 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 10:38 |
use sliding mesh to simulate unsteady flow | annie | FLUENT | 3 | November 9, 2004 08:48 |
