Problem in laminar natural convection in cavity |
June 26, 2014, 07:06 |
Rep Power: 12 |
hi every one
i have modeled a 2d cavity in fluent and openfoam for natural convection heat transfer they gave me the same results but not the same with the experimental results. so i'm asking for your advices the upper edge in cavity is adiabatic and left and right wall are in constant temp (Tc) and a part of lower wall is in constant temp(Th) and some part of it are adiabatic i have attached the steps i used in modeling the problem in fluent and the results as well i really need your helps because i;m about to fail my coarse!!! thank you in advance Nuextent.xlsx 2.JPG 3.JPG 4.JPG 5.JPG |
June 26, 2014, 09:44 |
Mustafa
Rep Power: 13 |
From density choose boussniq
June 26, 2014, 10:09 |
Rep Power: 12 |
June 27, 2014, 06:10 |
asking for help
Rep Power: 12 |
anyone ????
please i need help!! |
June 27, 2014, 10:55 |
Rep Power: 24 |
Make sure that Nusselt number is calculated the same way in simulation and experiment. Nusselt number in fluent is calculated as,
with . q is the local heat flux, k is the local heat conductivity. The reference values are defined in the corresponding panel "reference values" in fluent (Length and Temperature). |
June 27, 2014, 11:47 |
Rep Power: 12 |
i used Forward finite difference scheme for calculating Nu Nu was defined as d(teta)/dY teta is the dimensionless temperature Y is the dimensionless lenght |
Natural convection convergence problem | Bruno Machado | FLUENT | 10 | January 31, 2018 05:18 |
Problem with natural convection | claudia.h | FLUENT | 2 | July 3, 2012 04:10 |
transient simulation: natural convection problem? | Basics | CFX | 3 | September 25, 2002 10:42 |
ON TURBULET MODEL FOR A NATURAL CONVECTION PROBLEM | varghese | FLUENT | 6 | February 6, 2002 06:23 |
Natural Convection Problem | Sridhar | FLUENT | 2 | September 13, 2001 16:16 |
