June 25, 2014, 21:37 |
capillary tube simulation
MI
Rep Power: 12 |
Hi all,
recently i am doing a capillary tube simulation by FLUENT. capillary tube dimension and simulation result are showing below(unit is mm).dimension.jpggeometry.jpg For the parameters setup, basically i follow Fluent tutorial about VOF model. 1. i use pressure-based, transient solver. 2. VOF model is used. and scheme is explicit scheme. 3. water and air is used as material. air is primary phase and water is secondary phase. wall adhesion option is selected and surface tension coefficient is 73.5dyn/cm. 4. I use pressure inlet and pressure outlet. for both of them, gauge presseue is 0. and water volume fraction is 1 at inlet and 0 at oulet. 5. For wall, contact angle is 30deg. 6. for the solution method, i use PISO scheme. 7. since i meet some convergent problem at beginning, i change all the relaxation factors to 0.25. But the result is weird.result.jpg i expect water flow would go downward when it pass the tee. But it go upward... do i miss gravity setup or the geometry itself cause this problem??.. help!!help!! thank ahead |
June 30, 2014, 07:38 |
Márton Stibrányi
Rep Power: 12 |
What is the BC at the bottom? You should define pressure outlet for both the top and bottom boundary. Enable gravity and specify the operating density to 0.
What are the initial conditions? Air everywhere? |
June 30, 2014, 09:20 |
#3 | |
MI
Rep Power: 12 |
and also i think my geometry may not be proper. i will try to change it a little bit. |
June 30, 2014, 11:55 |
Márton Stibrányi
Rep Power: 12 |
I meant that you should define pressure outlet at both end of the vertical tube.
June 30, 2014, 12:07 |
MI
Rep Power: 12 |
Shock tube simulation in Fluent | Vinoo_P | FLUENT | 28 | September 6, 2018 01:21 |
What is best mesh for cylinder tube? | olivia | FLUENT | 7 | January 16, 2014 06:55 |
Convergence of jet flow simulation | MiraLisa | FLUENT | 0 | August 15, 2013 05:44 |
[Other] How to set up a dynamic mesh for a piston moving through a tube of variable diameter? | karkar | OpenFOAM Meshing & Mesh Conversion | 0 | July 4, 2012 07:54 |
Numerical simulation of Shock tube problem | p07ip705 | Main CFD Forum | 0 | May 28, 2012 03:00 |
