June 16, 2014, 09:40 |
Modeling non ideal gas
Fraiman Leonid
Good day everyone,
I am trying run a simple cross flow heat exchanger using N2 fluid. The temperatures range is 90 - 300 [K]. I have two streams, H@10 MPa and L@0.1 MPa. I using temperature depended properties, i got from NIST site. My question is regarding energy equation being solved by fluent. As I understands it Enthalpy is calculated using h=cp*T releation. The L stream N2 acts much like ideal gas, when H stream not. It means h from NIST tables and cp*T are not behaves the same, h closely linear with T, cp not at all. Should i modify my cp data, to fit: h - h.ref = cp* (T - T.ref ) ? |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
error message | cuteapathy | CFX | 14 | March 20, 2012 07:45 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 09:56 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 13:02 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 23:02 |
