Fluent15: received a fatal signal (Segmentation fault)
Old   June 12, 2014, 17:21
Default Fluent15: received a fatal signal (Segmentation fault)
Chenguang Li
lcg44 is on a distinguished road
Hi all,
I just don't know why I meet this error once I begin to run a multiphase case with UDF.
The case could run well in Fluent 13.
So strange....
Please help me.
Chenguang
lcg44 is offline   Reply With Quote
Old   June 13, 2014, 04:32
pakk will become famous soon enough
I also don't know why you got this error.
I tried to look at your UDF to see what can be causing the problem, but since you did not include the UDF in your question, I can only guess.
So: Maybe there is a typo in line 8 of you udf?
Did this help you?
pakk is offline   Reply With Quote
Old   October 19, 2014, 20:32
Tleja
Tleja is on a distinguished road
My case is Fluidized bed in 2D. I have to patch Zone of solid before simulation.
I also meet the same error "Error: received a fatal signal (Segmentation fault)"
while i begin to run a multiphase(2 mixture phase:solid,gas) with reaction.Not including UDF file
But i have already set my case in 3D. It's ok.
I don't know why i can only set the same setting in 3D Fluidized bed.
Please help me know
Tleja
Tleja is offline   Reply With Quote
Old   August 29, 2016, 09:06
Default Segmentation fault
saad
s.m.saad jamil is on a distinguished road
I am trying to add the source term in the momentum equation and epsilon equation. but when i am trying to run the simulation it is showing fatal error/ segmentation fault. My UDF is
# include "udf.h"
# include "mem.h"
# define domain_ID 1
DEFINE_ADJUST(adjust_gradient, domain)
Thread *t;
cell_t c;
face_t f;
real temp_gradient_y, vel_gradient, di,k;
domain = Get_Domain(1);
thread_loop_c(t,domain)
begin_c_loop(c,t)
if (NULL != THREAD_STORAGE(t,SV_T_RG))
temp_gradient_y = C_T_RG(c,t)[1];
C_UDMI(c,t,0)=temp_gradient_y;
else
/* first iteration OR option to store gradients not turned on */
temp_gradient_y = 0.0;
end_c_loop(c,t)
/* Fill UDS with the variable. */
thread_loop_c (t,domain)
begin_c_loop (c,t)
C_UDSI(c,t,0) = C_U(c,t);
C_UDSI(c,t,1) = C_K(c,t);
C_UDSI(c,t,2) = C_D(c,t);
end_c_loop (c,t)
thread_loop_f(t,domain)
if (THREAD_STORAGE(t,SV_UDS_I(0))!=NULL)
begin_f_loop (f,t)
F_UDSI(f,t,0) = F_U(f,t);
F_UDSI(f,t,1) = F_K(f,t);
F_UDSI(f,t,2) = F_D(f,t);
end_f_loop (f,t)
begin_c_loop (c,t)
vel_gradient = C_UDSI_G(c,t,0)[1];
C_UDMI(c,t,1) = vel_gradient;
k = C_UDSI(c,t,1);
C_UDMI(c,t,2) = k;
di = C_UDSI(c,t,2);
C_UDMI(c,t,3) = di;
end_c_loop (c,t)
DEFINE_SOURCE(mom_source,c,t,dS,eqn)
real x[ND_ND];
real source;
C_CENTROID(x,c,t);
source= 1418000*(C_T(c,t)-1.5);
dS[eqn]= 0.0;
return source;
DEFINE_SOURCE(G_source,c,t,dS,eqn)
real x[ND_ND];
real souurce;
C_CENTROID(x,c,t);
souurce= -(C_UDMI(c,t,0)*C_UDMI(c,t,1)*C_UDMI(c,t,2)*C_UDMI( c,t,2)*64448.1)/C_UDMI(c,t,3);
printf("temp_gradient:%g\n", C_UDMI(c,t,0));
printf("vel_gradient:%g\n", C_UDMI(c,t,1));
dS[eqn]= (C_UDMI(c,t,2)*C_UDMI(c,t,2)*64448.1*C_UDMI(c,t,0) *C_UDMI(c,t,1))/(C_UDMI(c,t,3)*C_UDMI(c,t,3));
return souurce;
Please help me Pakk.
s.m.saad jamil is offline   Reply With Quote
Old   August 29, 2016, 13:19
duri
duri is on a distinguished road
I couldn't notice any bug or uninitialized variable in the code. Are you sure all user defined memory are allocated before running the code?
duri is offline   Reply With Quote
How to remove the error:FLUENT received a fatal signal (SEGMENTATION VIOLATION). Conan FLUENT 9 December 20, 2019 13:31
VOF model error:Cortex received a fatal signal (SEGMENTATION VIOLATION) Sdezmond Fluent Multiphase 4 July 20, 2017 04:03
fluent 13.0.0 received a fatal signal (SEGMENTATION VIOLATION)) alinik FLUENT 1 January 9, 2014 11:21
FLUENT received fatal signal (ACCESS_VIOLATION) osamaghani FLUENT 2 March 31, 2012 17:15
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
