return values from udf
Old   June 12, 2014, 10:59
Default return values from udf
Garvit Goel
garvitgoel is on a distinguished road
hi,
What happens to the values that are returned from the UDF? How can I access them in fluent?
Thanks
garvitgoel is offline   Reply With Quote
Old   June 12, 2014, 11:26
pakk will become famous soon enough
You will need to be more detailed than this, there is no "the UDF", all UDFs are different...
Can you give an example of a UDF, and mention which values you would like to access in Fluent?
pakk is offline   Reply With Quote
Old   June 12, 2014, 15:37
Bionico's Avatar
Flavio
Bionico is on a distinguished road
Hi garvitgoel,
tell me if I understood weel: do you want to display some values in text user interface? in this case you have to use printf command
Regards
Bionico
Bionico is offline   Reply With Quote
Old   June 16, 2014, 11:25
Garvit Goel
Actually, I want know how I can print in the graphics area, where all the graphics are printed.
Thanks
Old   June 16, 2014, 14:14
Seriously. If you have a DEFINE_PROFILE that gives velocities, you need a completely different solution than if you have a DEFINE_TIMESTEP that defines which timestep your simulation has. Be specific. Or if you have no specific example, choose one.
Modified k-e turbulence model UDF Travis Fluent UDF and Scheme Programming 7 November 11, 2018 21:21
I want to Change Values in Existing UDF to Match my Model mamkol Fluent UDF and Scheme Programming 1 April 26, 2013 03:57
I want to write a UDF for atmospheric boundry layer profile mamkol Fluent UDF and Scheme Programming 0 April 12, 2013 12:55
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
cell values in UDF gayatri FLUENT 2 February 27, 2007 19:18
