Wall thickness
Old   June 4, 2014, 10:29
Default Wall thickness
magicalmarshmallow is on a distinguished road
I have an obscure conjugate heat transfer problem which I am solving using FLUENT.
What I have is a sandwich structure, whereby I have a Hot block of metal (Al) in contact with a gap filler in contact with a Cu pipe, which has water flowing within it.
Al
Gap-filler
Cu
Water
I have computed this without a wall thickness for the "Al-gap-filler" and "Al-gap-filler-shadow" and "gap-filler-Cu" and "gap-filler-Cu-shadow". This gave results much further than the experimental. Hence I defined a "Wall Thickness of 0.005 m.
What I want to know is how to convert this to an interfacial resistance of W/m^2 K, similar to the input parameter in CFX. Has anyone any ideas about this or if it can be done?
Cheers
M
magicalmarshmallow is offline   Reply With Quote
conjugate heat transfer, fluent, interfacial resistance, wall thickness
Wall treatment with OpenFOAM roby OpenFOAM Running, Solving & CFD 48 May 28, 2021 12:38
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 13:03
modelling wall thickness coupling (like fluent) in cfx suryawanshi_nitin CFX 3 April 13, 2009 02:25
first wall layer thickness and droplet size itchie CFX 3 May 14, 2008 10:03
thickness off wall Ahlem FLUENT 1 February 20, 2007 23:45
