Natural Convection 2D axisymmetric turbulent simulation
Old   June 2, 2014, 14:20
Default Natural Convection 2D axisymmetric turbulent simulation
Joe
enayath is on a distinguished road
I am trying to model natural convection in a closed domain. I use K-e/realizable and with enhanced wall treatment and with fully buoyancy feature on. 2 problems exist:
1- I cant not set turbulent BC for my BCs...the turbulent feature is not activated...Do I need to change my BC type from wall to other thing?
(now all of them are wall-axis of symmetry and interior)
2- When I start to calculate with current settings, fluent runs but the continuity residual is in order of 10e4!
energy 10e-10,K,epsilon,x and y velocity 10e-6,
Any ideas how to handle these two problems?
Thank you
enayath is offline   Reply With Quote
Old   June 3, 2014, 06:19
Bionico's Avatar
Flavio
Bionico is on a distinguished road
Hello enayath,
can you post a picture of your problem?
1) If you have a closed domain (a room, for example) you shouldn't define turbulence BC;
2) Natural convection problem usually are difficult to converge, check your mesh first of all
Regards
Bionico
Bionico is offline   Reply With Quote
Old   June 3, 2014, 11:15
Joe
Hello Bionico,
Thanks for the reply. As can be seen, the domain is closed...so for your first note, what should I do for the BC? How Fluent can detect the type(laminar or turbulence) if I do not specify the BCs? just by setting laminar or turbulent in models I am done?
About the second point, I am pretty sure the quality of mesh is not bad.
Minimum Orthogonal Quality = 5.83808e-01
Maximum Aspect Ratio = 4.65313e+00
Max Skewness:0.64
The values of Y plus is less than 5 which means the mesh is pretty good for heat transnfer calculation.right?
Any other idea how to limit the residual for the continuity?
Thank you,
Hooman
Old   June 4, 2014, 05:09
Bionico's Avatar
Flavio
Hello enayath,
when you define the turbulence model, Fluent solves the equations of Fluid dinamics with turbulence parameters. So if you have an open domain you can define turbulence intensity (for example) in inlet; in closed domain instead you can define BC as Wall Temperature, Wall flux etc.
It's difficult to converge natural convection in closed domain: I suggest using boussinesq approximation for density in Material Menu and RNG k-epsilon as turbulence model.
Moreover you should set up a transient simulation because it converges better in such a case.
Regards
Bionico
Old   June 4, 2014, 11:20
Joe
Bionico,
I do not want to use boussinesq approximation as the temperature difference is not small(the minimum is 30) and based on what I searched for maximum deltaT=20, we can use boussinesq approximation. I want to give the unsteady answers as the initial for transient calculation. I tried also for transient.it is still high for the continuity residuals.
Hooman
Specifying turbulence parameters for natural convection on vertical flat plate abu250feldman FloEFD, FloWorks & FloTHERM 2 May 5, 2014 14:42
Turbulent natural convection in a veritcal cylinder m.vegad Main CFD Forum 0 March 28, 2014 04:54
Natural Convection: Energy residual does not converge Nukengine STAR-CCM+ 1 April 10, 2013 09:53
simulation problem -- convection BC pras FLUENT 4 January 30, 2013 11:41
Natural Convection in closed hydrothermal system Scott FLUENT 0 March 24, 2008 20:46
