FLUENT divergence on cluster not on local machine |
May 14, 2014, 07:35 |
Thibault
Rep Power: 12 |
Hi all,
I made this simple test case with an axisymmetric half sphere at low Re. When I run fluent on my local machine the solution converges, when I run the exact same problem on a linux cluster the problem diverges.. Does anyone know why this is and how it can be avoided? Thanks! |
May 14, 2014, 14:57 |
vlg
Rep Power: 18 |
Are FLUENT versions indentical? And do you use windows version on your machine?
cluster, convergence, divergence, fluent |
Problem in using parallel process in fluent 14 | Tleja | FLUENT | 3 | September 13, 2013 11:54 |
problem in using parallel process in fluent 14 | aydinkabir88 | FLUENT | 1 | July 10, 2013 03:00 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 23:40 |
Problem running a parallel fluent job on local machine via mpd | highhopes | FLUENT | 0 | March 3, 2011 06:07 |
Rent time on CFD machine to solve FLUENT model | Jeff | FLUENT | 6 | October 6, 2006 14:29 |
