Flow around sphere using 2D axisymmetric
Old   May 13, 2014, 12:27
Question Flow around sphere using 2D axisymmetric
Thibault
Thibalt is on a distinguished road
Hi all,
I have a small question using 2D axisymmetry.
When simulating following problem in FLUENT, do I need to multiply the drag by factor 2 because I'm working with half a sphere? Or is the drag output from FLUENT already for a full sphere?
Image of the problem:
Thanks!
Thibalt is offline   Reply With Quote
Old   May 13, 2014, 12:47
Ali Jafarizade
jafarizade is on a distinguished road
hi
i am not sure but i think yes you should multiply it by two.
jafarizade is offline   Reply With Quote
Old   May 14, 2014, 04:39
Thibault
Thanks for the answer, I would also think that I should double it. However, my results look more doubtful then.
Old   May 15, 2014, 01:01
Ali Jafarizade
hi thibalt
did you check the reference values?
what did you put for the reference area?
it is important for making the drag doule or not.
best regards
ali
Old   May 15, 2014, 05:33
Thibault
Thank you jafarizade for your answer,
I use the drag force from FLUENT and not the drag coefficient calculated by the software using the reference values.
When I calculate Cd with the area of a full sphere, the solution matches experimental data. This seems weird since I did not double the drag data. So does this mean that the drag output is already for a full sphere?
Old   May 15, 2014, 06:02
Ali Jafarizade
hi thibalt
i am not sure
but i think some thing else is wrong and you should make the drag double.
best regards
Ali
Old   May 15, 2014, 06:05
Thibault
Ok thanks! I will try to figure it out!
Old   May 15, 2014, 06:08
Ali Jafarizade
good luck thibalt
axisymmetric 2d fluent, drag, drag coefficient, flow, sphere
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 8 October 5, 2018 18:02
3D axisymmetric flow in cylindrical coordinate = 2D cartesian flow? shubiaohewan Main CFD Forum 10 May 2, 2013 15:08
Boundary condition in an axisymmetric 2D flow jinwon park Main CFD Forum 4 July 23, 2012 14:55
axisymmetric main flow + injection Stephan FLUENT 1 January 19, 2006 12:43
Axisymmetric Flow S. Kumar Main CFD Forum 0 November 10, 2001 11:15
