Patching sand in fluidized bed
Old   May 8, 2014, 14:32
Default Patching sand in fluidized bed
Maaz Ul Mosaid
maazulmosaid is on a distinguished road
I am modeling a fluidized bed.
I want to patch sand bed.
Please guide me about which multiphase model should i choose and how to patch the sand. waiting for reply
maazulmosaid is offline   Reply With Quote
Old   December 3, 2016, 13:13
Default How to a Patch Secondary Phase
Dri
Adriana
Dri is on a distinguished road
Well hope this is not too late.
It depends on how complex and detailed you want the solution to be.
I use eulerian-granular model. After you set up the models (multiphase, laminar/turbulent regime, etc) materials, boundary conditions, solution methods, solution controls, and monitors, go to the solution initialization tab, and click the initialize button.
Go to the mark/adapt cells, and enter the dimensions of the region that you want to patch. For a 2D geometry, for instance, you need to give a Xo and Xmax and Ymin and Ymax. if you don't recall the dimensions of your geometry, just go to General/scale/and take a look at the domain. Once you added the numerical values, click on the "Mark" button. After clicking this button, you will see in the console a message, telling you how many cells were marked.Usually the name is hexahedron-1 (depending on the shape that you select in the mark/adapt cells)
Go back to the solution initialization tab and select the "Patch ..." button. Select the phase-2 in the Variable window. Select volume fraction which will enable the "Value" entry, and add your numerical value. Then, click on the hexadron-1 (or something with a similar name) in the " Register to Patch" window. Click the "Patch" button.
To make sure that your region has been patched, go to graphics/contours/volumefraction/phase-2.
Dri is offline   Reply With Quote
Old   December 3, 2016, 16:19
Antanas is on a distinguished road
Two years man! No, you aren't too late.
Antanas is offline   Reply With Quote
coal, combustion, sand
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
patch error OF v2.2.2 mac hewei OpenFOAM Installation 4 November 30, 2013 17:55
2.0.x on Mac OSX niklas OpenFOAM Installation 74 March 28, 2012 17:46
Fluidized bed simulation VS particle tracking windhair CFX 2 June 28, 2011 22:10
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
