Free Surface Flow
Old   May 5, 2014, 21:32
Default Free Surface Flow
anup radhakrishnan
anuprdk is on a distinguished road
I am trying to simulate an open channel flow. I am experiencing some issues with respect to the model as it exits automatically and hence I have attached a couple of slide shots pertaining to the definitions of the input data for clarification.
The domain is defined as: 5 x 2 x 0.9 m with origin at the point (0,0,0)
I have chosen a time dependant (Transient) 'Pressure based' solver with gravitational constant in the specific direction.
Primary phase - air
secondary phase - water
Are boundary conditions to be defined only for the mixture and not for individual components? I want the air to remain stationary. How to do that?
The boundary condition for the free surface (top_wall) has also been defined as 'Pressure outlet' as shown in the attachment.
The solution is initialized by computing from 'Inlet' with the 'Open channel initialization method' being 'Flat'. Following this a 'Region' corresponding to water till the free surface is 'Marked' and 'Patched' with Volume fraction as 1. I did not 'Adapt' it though.
Can any one please pour in some advice on the procedure followed. The iteration commences with 'Reversed flow' in so and so faces and finally it quits automatically.
Thanking you,
Anup
anuprdk is offline   Reply With Quote
Thermocapillary free surface flow zakifoam OpenFOAM Running, Solving & CFD 10 December 12, 2016 12:44
CFX gravity driven free surface flow tutorial mechovator CFX 37 July 27, 2009 11:28
free surface flow in non-inertial reference frame Tiedingg FLOW-3D 1 February 26, 2009 20:51
Free surface flow simulation question Jane Luo FLUENT 1 April 23, 2004 05:26
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
