The residual of vf -phase-2(vapor) become zero? |
May 5, 2014, 04:12 |
cuocuozhuo
Rep Power: 12 |
I am using Fluent to simulate the flow with cavitation.
Firstly, I choose mixture and k-e model, phase-1 is water liquid, phase-2 is water vapor. Pressure of inlet is 202650Pa and outlet is 0Pa. Caculating it until the convergence. Secondly, add Singhal-Et-Al Cavitation Model, set vaporization 3540Pa. Continue to caculate. However,the residual of vf-phase-2(vapor) become zero soon and the residual line of it disappears. My question is it possible the residual is zero and why? Is this result reasonable? Looking forward your help. Thanks. http://a4.images22.51img1.com/6000/3...175e52eba0.png |
January 19, 2019, 17:15 |
saima
Rep Power: 9 |
do you remember how did you solve this problem i am facing the same while simulating cavitation
cavitation, phase-2, residual, vapor |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 03:20 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 14:12 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 09:35 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 07:37 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 06:24 |
