Supersonic Nozzle Exhaust Simulation
Old   May 1, 2014, 22:28
Default Supersonic Nozzle Exhaust Simulation
Mike H
mikeh is on a distinguished road
I am having difficulty setting up a FLUENT13 simulation of a supersonic nozzle. I am relatively new to CFD and have had some success with simple convergent-divergent nozzle geometries, however, I find it very difficult to get convergent repeatable results with even small changes to the problem setup.
My problem is basically a convergent divergent Venturi tube with a fixed inlet pressure. The nozzle exhausts into atmosphere at supersonic velocities and I am particularly interested in modelling the flow in the output domain.
From tutorials for 2d-axisymetric nozzles I have had limited success in modelling the flow within the nozzle without including the output domain in the simulation, but simply putting a pressure outlet boundary at the nozzle end.
Presently I am attempting to use 3D solid model of my part reduced to a 45° sector and using periodic rotational boundaries in the simulation. I have enclosed my entire cylindrical nozzle in a large cylindrical domain that is many times the diameter and length of the part with one end aligned to the nozzle inlet port.
My simulation setup is:
  • Density based solver, 3D, steady state
  • Standard k-e model
  • Default mesh with inflation at the part boundaries (looks reasonable to me). 352k cells.
  • Fluid is ideal gas air
  • Pressure inlet defined (with a supersonic guess pressure) with 1% turbulent intensity
  • All far-field boundaries defined as "outlet-vent" at 100kPa, turbulent intensity set to 0.
  • Solution method: Explicit, Roe-FDS, Least squares, second order flow, first order turbulence.
The simulation residuals are quite unstable and eventually it will diverge. If stopped at a minima the results look somewhat reasonable.
I would greatly appreciate any advice on how to get my simulation to converge more reliably without oscillation. I am hoping that I can find a setup that will allow me to vary nozzle geometry without disturbing the sim parameters.
mikeh is offline   Reply With Quote
Pressure Driven Supersonic Flow in Converging-Diverging Nozzle cdm OpenFOAM Running, Solving & CFD 7 August 28, 2019 02:37
Supersonic nozzle Danny Tan Main CFD Forum 9 April 15, 2017 16:59
Supersonic nozzle exit conditions Betty Main CFD Forum 13 May 24, 2012 01:26
Nozzle flow simulation in inviscid and viscous Cath FLUENT 0 January 28, 2007 03:16
jet structure at the end of a 2D supersonic nozzle N Menon CFX 1 November 7, 2001 09:04
