The issue with gravity!!!
Old   May 1, 2014, 09:42
Default The issue with gravity!!!
Virendrasingh Pawar
virendra_p is on a distinguished road
hi friends.. good day!!!
i am simulating flow in a pump-sump using VOF model. My geometry has a rect. tank...a cyc. pump and a rect. air domain (over rect. tank)...i have realised transient simulations w/o any problem...( gravity is defined, also buoyancy)........
for steady state simulations gravity is causing some problems !!!!
i) if low gravity values are used (0.001)....simulations work fine
ii) if gravity is increased further....absurd flow patterns are generated
Q1) Should gravity be defined at all???
Q2) Why problem arises only with steady state simulations, and how to resolve it?
THANK YOU!
virendra_p is offline   Reply With Quote
Convergence problem when use gravity aroma STAR-CCM+ 1 April 10, 2013 11:18
Question on Gravity archdevil Main CFD Forum 9 May 16, 2012 14:31
UDF fails to model 9.81m/s^2 gravity jpo Fluent UDF and Scheme Programming 2 January 24, 2012 19:15
how to consider gravity in CFX shrimp CFX 4 September 8, 2008 21:41
On gravity modelling... Drona CFX 7 November 22, 2001 11:28
