Vertical Pipe water flow
Old   April 30, 2014, 09:25
Question Vertical Pipe water flow
Goutam Saha
Goutam is on a distinguished road
I have validated the water flow in horizontal circular pipe using 2D axi-symmetric model (x direction->horizontal and y direction->radial) under laminar, transition and turbulent flow regime.
Now I want to use vertical pipe with and without boussinesq approximation.
For Without boussinesq approximation case:
In operating condition panel, I set the gravity on along x direction = -9.81.
I completed the simulation, and found that radial V, T and local Nu along the pipe is same as horizontal pipe. Only difference is Pressure drop is lower for vertical pipe. How to know the results are correct?
For With boussinesq approximation case:
In operating condition panel, I set the gravity on along x direction = -9.81. Also set the operating temperature which is same as inlet temperature.
In material panel, constant density is replaced by Boussinesq and value of beta is set.
I completed the simulation and found that velocity profile form like M-shape which I think correct. But wall temperature along the pipe becomes smaller than bulk temperature.
I am bit more confused. Is there any reference research papers related to this? Any suggestions please .
Thanks
GS
Goutam is offline   Reply With Quote
boussinesq approximation, vertical pipe
flow from water pipe leak to sand domain tangfl ANSYS 1 May 13, 2013 05:15
Slug flow modelling in vertical pipe using ansys software 12.1 kwasi FLUENT 5 April 9, 2013 22:00
Periodic boundary conditions for 2D pipe (water flow). thess FLUENT 3 May 31, 2012 14:38
codes for water hammer on pipe flow park Main CFD Forum 0 September 28, 2008 02:43
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 14:19
