Error in heat transfer - water in pipes
Old   April 30, 2014, 06:40
Default Error in heat transfer - water in pipes
Rum
rum131 is on a distinguished road
Hi All,
I have tried to look through these forums with no avail.
My problem is this:
Flat plate with a thickness has a pipe running inside. On top of the flat plate there is a heat source (box with constant heat flux) and the pipe has a coolant running through it. I want to investigate the heat transfer from the heat source>plate>cooling pipes. All these components are contained in a larger box. The gas in this large box is N2. The coolant is to be water-liquid.
When I run the coolant as water my simulation instantly diverages, however running both ambient and coolant fluid as N2 it works.....any ideas?
rum131 is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Heat transfer (conduction) between two pipes shields FLUENT 14 February 3, 2016 08:45
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 23:53
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
