April 29, 2014, 14:33 |
Porous zone from Fluent
Rep Power: 13 |
HI you all,
I want to work with porousInterFoam with a geometry defined in IGES. I'm meshing it with fluent (any good opensource program to mesh with faces selection for openfoam?) defining which patches is which. I want to set a porous zone on it. I was wondering if there is anyway, like when you create a box of alpha liquid in interFoam, or any other way to say "This part is porous and must have those properties". May I have to define the porous zone on fluent? Any ideas? Thx in advance |
May 1, 2014, 13:21 |
Lucky
Rep Power: 66 |
You can specify the porous zones in Fluent. When gridding, just make sure you've gridded each region appropriately, surfaces & volumes.
It helps if the grid has disjoint volumes so that Fluent instantly recognizes separate volumes when the grid gets imported. Otherwise you have to manually split the volumes in Fluent. I don't know how to do this in ICEM but usually applying fluid to one region and solid to another region gets most packages to treat them as different regions. Once in Fluent you just change the solid back to fluid and activate porous region. |
mesh, porous, set porous |
FLUENT porous zone inputs | eishinsnsayshin | FLUENT | 19 | April 17, 2020 05:40 |
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) | Aadhavan | OpenFOAM Meshing & Mesh Conversion | 2 | March 8, 2018 02:47 |
[GAMBIT] periodic faces not matching | Aadhavan | ANSYS Meshing & Geometry | 6 | August 31, 2013 12:25 |
Segmentation Fault in fluent3DMeshToFoam | cwang5 | OpenFOAM Bugs | 23 | April 13, 2011 16:37 |
Fluent incident radiation problem | Michael Schwarz | Main CFD Forum | 0 | October 21, 1999 06:56 |
