Rotor 67 simulation FLUENT
Old   May 8, 2014, 07:12
mohamed mohsen
sehs15 is on a distinguished road
the non reflecting boundary is an option in the pressure outlet boundary conditions .. it is used to eliminate pressure waves reflecting from the outlet boundary and treats it like the boundary is set at infinity ... rotor 37 mesh is the same as 67 im just using reasonable aspect ratio as im not refining too much at the walls .. try to solve laminar and tell me what u got
sehs15 is offline   Reply With Quote
Old   May 8, 2014, 15:25
RacMat
rvl565 is on a distinguished road
Just finished with the laminar simulation... reversed flow at the outlet and inlet and a lot of oscillations in the mass flow rate :'(
rvl565 is offline   Reply With Quote
Old   May 9, 2014, 15:32
mohamed mohsen
what boundary conditions do u use?
Old   May 10, 2014, 12:18
RacMat
Pressure Inlet and pressure outlet (averaged specification)...
Old   January 15, 2015, 06:21
AndreiCFD
andrei.cimpoeru is on a distinguished road
Hi All
Has anyone got a fluent mesh for the rotor67 ?
Thanks
Andrei Cimpoeru
andrei.cimpoeru is offline   Reply With Quote
Old   September 20, 2018, 09:36
Default Fluent Boundary Conditions Rotor 67
  #26
Umer Sohail
MUSohail is on a distinguished road
Hello all
i need guidelines and help from you all. I have done Rotor 67 steady state simulation in CFX and found great results and even validated with NASA results. Now i want to do same simulation in Fluent. I imported Nasa Coordinates and mesh it in turbogrid. Now i am having reverse flows in fluent.
Kindly guide me the boundary conditions in fluent, such as inlet and outlet gauge pressure etc.
Please
MUSohail is offline   Reply With Quote
Old   September 20, 2018, 09:37
Default Rotor 67 Fluent
  #27
Umer Sohail
Hello all
Please
Old   September 20, 2018, 10:01
Umer Sohail
Originally Posted by rvl565 View Post
Hi i wanted to use rotor 67 as a test case for fan simulations.
To speed up the process i am using the mesh provided by stanford university ( http://aero-comlab.stanford.edu/vdweide/CGNSFiles/ )
I removed the tip clearance from this mesh, other than that the mesh is the same.
I am using the MRF model. The boundary conditions are:
Pressure inlet: total pressure = 101325 ( 0 reference pressure)
Initial gauge pressure =99825
% intensity =1
length scale =0.01
Pressure outlet: gauge pressure 114500
backflow length scale and intensity the same as inlet
Rotor RPM: -16043
I extended the inlet and outlet by 0.15m to create two stationary zones.
I used the komegaSST model with compressibility effects and curvature correction.
The energy equation has been turned on and used the ideal gas equation for the density.
I get reversed flow at the inlet and outlet.
Please help me correct this problem.
Thanks!
Hello all
Please
fan, mrf, rotor 67, transonic fan
simulation of Double pipe heat exchangers in FLUENT teguhtf FLUENT 1 November 6, 2014 03:42
Question about starting the simulation automatically one after another by Fluent Anna Tian FLUENT 1 January 23, 2014 20:23
Simulation on fluent 14 NAD FLUENT 0 September 11, 2013 03:05
problem in using parallel process in fluent 14 aydinkabir88 FLUENT 1 July 10, 2013 03:00
Can Fluent start a simulation from a negative time Ted Chu FLUENT 10 November 26, 2008 22:06
