April 28, 2014, 11:03 |
rigid body's motion with DOF in Fluent
Rep Power: 14 |
Hi all,
I am modelling a particle's freefalling motion with DOF in a container. I think my model, including remesh and dynamic mesh is okay. But, the final result is not quite different from theory. My fluid is with a constant viscocsity of 1 Pa s. Particle's material is glass, which density is 2500 kg/m3, and diameter of paticle is 1mm. According to Stokes' Law, terminal velocity of particle should be around 0.0028 m/s, But the result from my model is 0.5 m/s. I have checked the cas file again and again, unfortunately cannot find any problem. so any suggestion from all? thank you in advance. |
coupled motion using six dof udf but with restraints | fluentuser2003 | Fluent UDF and Scheme Programming | 0 | September 4, 2012 16:51 |
Rigid body motion + Boundary Layer | Manoj Kumar | FLUENT | 4 | May 26, 2012 11:34 |
Can anybody tell me what does fluent do using MESH MOTION? | enry | FLUENT | 0 | October 6, 2010 13:54 |
few quesions on ANSYS ICEMCFD and FLUENT | Prakash.Paudel | ANSYS | 0 | August 12, 2010 13:07 |
fluent probelm"mesh motion udf" | bestrcsekhar | Main CFD Forum | 0 | November 2, 2008 02:38 |
