Rep Power: 0 ![]() |
Hi guys,
As many of you I'm doing my final degree project on VAWT. Mine is a 3-bladed 2.5 radius turbine, using the NACA 0012 airfoil. I have been facing some mistakes for so long and I can't find a way to solve them, that's the reason why I've decided to ask for help. I know reading a post this long is tiring so I really thank you in advance. I first run a steady simulation in order to use it as an initial solution for the transient case. I use 10 m/s for the inlet velocity. Then I move to the transient case, using the mesh motion with 4 rad/s. I use a time step of 0.0043611 (1º). But I can't get to have positive values for the cm. At first I only got negative ones, then I restarted the geometry and the mesh and eventually got both positive and negative values, but very low ones. I think the problem should be in the setup, so I'm posting it here to see if anyone sees something wrong. -For turbulence I use the sst model (4 eqn) -For the reference values, I set area as the diameter and length as the radius (all the others as default, computed from inlet) -In the transient case i use PISO as the pressure-velocity coupling (simple in steady), and presto for pressure (standard in steady), all the others I leave them as first order. I also attach some pictures of the mesh just in case they were needed. https://dl.dropboxusercontent.com/u/...2014.01.32.png https://dl.dropboxusercontent.com/u/...2014.01.02.png Thank you very much for your help. Pol. |
fluent 14.5, momentum coeficient, turbine, vawt wind turbine |
2D VAWT simulation - rpm ramp function? | Boloar | OpenFOAM | 8 | August 3, 2013 04:42 |
Requiring some help regarding tornado simulation | amarjogot | Main CFD Forum | 0 | June 20, 2013 12:26 |
3-D VAWT simulation using pimpleDyMFOAM not working | Naruto | OpenFOAM Running, Solving & CFD | 2 | May 30, 2013 05:49 |
Simulation of a complex wing in solidworks flow simulation | niels1900 | FloEFD, FloWorks & FloTHERM | 6 | April 20, 2011 10:44 |
Continuous vs interrupted simulation | sega | OpenFOAM Running, Solving & CFD | 4 | November 3, 2008 14:29 |
