Rep Power: 12 ![]() |
Hi people!
How can be difference in the exit mach numer between 2 nozzles with the same throat and exit areas, and with the same length? One nozzle is conical, and the second is designed using MoC....The Isoentropic realtions aren't correct in this case? I simulated the both nozzles in Fluent 6.3. Pressure inlet: Total Pressure: 101325 Pa Initial Pressure: 100000 Total Temperature: 293.15 K Pressure outlet: Gauge pressure: 5000Pa Backflow total Temperature: 122K The model is axisymmetric, solver density based. The exit Mach numer should be 2.61 - from the isentropic relations The exit Mach number of the Conical nozzle is 3.92Mach MoC nozzle is 5.97Mach... |
isentropic, laval, moc, nozzle |
Guide: Writing Equations in LaTeX on the CFD Online Forums | pete | Site Help, Feedback & Discussions | 27 | May 19, 2022 03:19 |
modelling Differential equations in a udf | RikardMNorén | Fluent UDF and Scheme Programming | 2 | October 1, 2013 03:36 |
Riemann invariants of adjoint equations of shallow water equations | zqb0929 | Main CFD Forum | 0 | March 15, 2012 00:54 |
CFD governing equations | m.gos | Main CFD Forum | 0 | April 30, 2011 14:21 |
Equations for finite difference, element & volume | W.L.C. | Main CFD Forum | 9 | April 3, 2001 12:08 |
