April 17, 2014, 16:29 |
Mixing tank impeller
Hello. I am trying to model a mixing tank with a single impeller. I am using a rotating reference frame, where I've created a cylindrical rotating fluid around the impeller and defined its rotation.
The problem I'm having is that, when run as steady state, the non-rotating fluid hardly seems affected by the rotating fluid (which in turn doesn't seem affected by the impeller). I've tried different impeller sizes/shapes/blades, but it hardly seems to have an affect on the flow, it mostly just looks like a rotating cylinder of fluid. In a 1000L mixing tank, I'm seeing very slow velocities away from the rotating fluid zone, 0.01 - 0.10 ft/s, with the rotating fluid moving at 200rpm. I have run the mixing tank in person, and clearly there is more activity irl. Any thoughts on what I'm missing? Last edited by Onicon; April 18, 2014 at 11:44. |
March 24, 2015, 02:43 |
Nataliia Tatyanko
Rep Power: 14 |
Hi, Onicon. I have the same problem as you. Have you decided this problem? I have two parts. One part is a rotating cylinder with emptiness inside in the form of mixer. And the second part is square tank, that surrounds rotating frame.
fluent, fluid, impeller, mixing, tank |
[ICEM] Tutorial of a mixing time tank equipped with an impeller | Alex69 | ANSYS Meshing & Geometry | 1 | July 18, 2013 03:24 |
how to start for modelling n meshing a mixing tank with impeller | jeevan | ANSYS Meshing & Geometry | 9 | July 16, 2013 07:06 |
3D mixing tank using MRF/SRF | cfd_confuse | FLUENT | 0 | October 2, 2010 03:46 |
What method use to modelate a side-entry impeller in a large scale mixing tank? | fcabrales | Main CFD Forum | 0 | January 29, 2010 14:24 |
To determine mixing tank with anchor impeller | p prajapati | FLUENT | 1 | December 12, 2007 15:27 |
