Fluent DPM chemical reaction
Old   April 15, 2014, 03:32
Default Fluent DPM chemical reaction
Sam
sunyilsh is on a distinguished road
Hi everybody
Can anybody help me regarding urea spraying in SCR(selective catalyst reduction) . I used DPM model to simulate urea solution spraying, breaking up of droplets, evaporation, and chemical reaction with exaust gas(continuous phase). However I am faced with questions as follows:
1. The specific meaning of "break up parcels" and so on.
2. The method of defining urea solution as one of material showed in injection panel. If use UDF, how to use it?
3. The custom laws of droplet particle doesn't have chemical reactions. How and where to add chemical reaction with exaust gas?
4. Do I need to use the nozzle model provided by fluent itself or set a model defined by myself?
Thanks
sunyilsh is offline   Reply With Quote
Old   April 21, 2014, 11:50
shoeb khan
shk12345 is on a distinguished road
Originally Posted by sunyilsh View Post
Hi everybody
Thanks
I am working on DPM since a long time.
I hope i may answer some of your queries.
1) Breakup means how many parcels are been breake up based on the instabilities that re in the flow. You may change the parameters of the breakup models primary or secondary and fine tune the amount of the particles being break up.
2)Just use the default material panel and provide the properties of urea there. Then use that urea in the DPM model.
3) I have no idea about it but i think there should be option of reactions in DPM.
4)Use the default models in fluent. Just fine tine them depending upon your injector.
Regards
shk
shk12345 is offline   Reply With Quote
Old   April 23, 2014, 02:55
Default DPM chemical reaction and parcels
Sam
Regards
shk
Thank you for your answers. Does the material of DPM droplets evapourate and then become one of the species of the continuous phase? If so, can I use the "species transport" model to finish the edit chemical reactions ?
I am also doubt about the your answer about "particle parcel". How can I edit the amout droplet contained in one parcel ?
Regards
chemical reaction, dpm, udf
What's the unit of heat of reaction in Fluent??? yerem3 FLUENT 1 December 26, 2019 06:17
chemical reaction modeling using FLUENT wlt_1985 FLUENT 6 April 16, 2014 08:45
chemical reaction in Fluent h.soltani Fluent Multiphase 0 November 24, 2013 17:28
DPM with reaction (a simple question) lili FLUENT 0 November 28, 2011 04:52
about defining chemical reaction Kim FLUENT 1 October 17, 2004 10:56
