Capture Laminar Separation Bubble with K-Kl Turbulence Model
Old   April 14, 2014, 14:16
Default Capture Laminar Separation Bubble with K-Kl Turbulence Model
alireza
alireza_b is an unknown quantity at this point
Hi
I tried to simulation transition flow over NACA 2415 airfoil. In my study, Reynolds Number is 200,000 and I compare my result with Genc's results (they do their work with fluent).
M. Serdar Genç, Ünver Kaynak, Hüseyin Yapici, "Performance of transition model for predicting low Re aerofoil flows without/with single and simultaneous blowing and suction", European Journal of Mechanics B/Fluids 30 (2011) 218–235
I used K-Kl turbulence models. turbulent intensity is 0.1% and turbulent ratio is 1.
I used second order discretization for all terms.
Y+ is less than 1.
unfortunately I couldn't get acceptable results. in that paper, they got cl=1.03 and cd=0.027.
But my result is far from that and my residual is oscillatory.
I tried this work:
1- solved with other turbulence models and then switched to K-Kl model.
2-I decreased under relaxation factors.
Dear friends
How can I get acceptable result.
alireza_b is offline   Reply With Quote
Laminar Separation Bubble and transition mrenergy FLUENT 2 June 12, 2023 09:50
Implement an les turbulence model pante OpenFOAM Programming & Development 19 December 5, 2014 17:16
How to decide to Turbulence model shipman OpenFOAM 2 August 18, 2013 04:00
Turbulence vs Laminar flow Soham Main CFD Forum 8 June 8, 2012 04:24
Is this understanding of turbulence models correct? 3kha Main CFD Forum 3 January 31, 2011 22:31
