UDF for turbulence model implementation
Old   April 12, 2014, 03:30
Exclamation UDF for turbulence model implementation
Luca
marluc is on a distinguished road
Hallo,
I have just written a UDF for the AKN model (Abe-Kondoh-Nagano).
I tested it for a channel flow, a backward facing step and a ribbed duct.
Upon reaching a convergent solution with a k-e model with enhanced wall treatment I switch off the calculation of the turbulence transport equations and, after initialization of the UDS, I solve for their transport equations, in order to compute the user-defined turbulent viscosity to use in the momentum equations.
My problem is when I first start with the UDS because I often get AMG solver divergence at the first iteration. So I first set the URF to very low values and solve for each UDS separately and without the momentum equations activated. Then I start increasing the URF and later I activate the flow calculation as well.
I am wondering if someone has the same problem when dealing with UDS for a user defined turbulence model.
Furthermore, when using the AKN model implemented in Fluent I can keep the default URF for momentum, k and e and the calculation converges. Does someone have an explanation for this? (actually Fluent and I should solve the same equations!)
Thank you in advance for your answers.
L.
marluc is offline   Reply With Quote
Old   July 10, 2017, 19:12
Vedamt Chittlangia
vcvedant is an unknown quantity at this point
Hello Luca,
Though this is an old post but were you able to get the solution to the problem. I face similar issue with AKN model.
Thanks
vcvedant is offline   Reply With Quote
turbulence modeling, udf, uds
UDF VOF model on Fluent baechtel Fluent UDF and Scheme Programming 7 January 20, 2016 19:13
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Problem with udf radiation model in 2d combustion model..???? shshiva17 FLUENT 0 July 28, 2009 10:44
UDF for Herschel-Bulkely model emad Fluent UDF and Scheme Programming 5 July 20, 2009 09:16
Real gas model with UDF Ed FLUENT 4 September 18, 2003 11:42
